adambou
#1 Posted : Monday, September 11, 2023 2:50:53 PM(UTC)
adambou
Scenario - during the football game I use a title to display try scorers name - select data sourcefrom list and then and overlay the title.
Id also like to display a list of try scorers at the end of the game.
Ideally - when i trigger the try scorer's name during the game - if vmix could take this data and use it to fill a field in a game summary title - well that would be great.
I have no idea about potential workflow to make this happen.
If anyone has any ideas id really appreciate it.
#2 Posted : Monday, September 11, 2023 4:55:05 PM(UTC)
one idea:
Every time a scorer name is displayed (triggered) call a script to write data pulled from the title and other details to add to a (CSV) Data Source file.
Use that datasource file to populate your summary title
adambou
#3 Posted : Monday, September 11, 2023 7:23:21 PM(UTC)
adambou
Brilliant idea.
Ive done lots of scripting but didnt know you could pull data from a title and add it to a CSV.
This would be the perfect solution. Whats the function for that?
#4 Posted : Monday, September 11, 2023 7:44:17 PM(UTC)
Brilliant idea.
see "scripting for dummies"post for examples of geting data from a title (retrieving by pulling it form the API XML or using Input.Find()
CHeck vb.net on how to write to a txt/csv file to use within a script
Guest (4)
