themoog
#1 Posted : Sunday, August 20, 2023 6:33:30 PM(UTC)
themoog
Hi All,
Following the tutorial for weather data -
Each time I add a new data source I get information, but then it doesn't update? The hamburger menu is red so shows live data sources.
Also JOSN call don't seem to be working? Work fine in a browser.
Any thoughts?
Thanks in advance
Neil
#2 Posted : Sunday, August 20, 2023 6:56:00 PM(UTC)
Red only means you have defined datasource not that they are set to autoupdate (play/pause indicator next to time interval)
What does not working mean ?
from the helpfiles"
"This supports JSON data that is stored as an object array.
Each element in the array will be treated as a row."
