VMIX data sources not updating (XML/JSON)
Hi All, Following the tutorial for weather data - Each time I add a new data source I get information, but then it doesn't update? The hamburger menu is red so shows live data sources. Also JOSN call don't seem to be working? Work fine in a browser. Any thoughts? Thanks in advance Neil
Originally Posted by: themoog  Each time I add a new data source I get information, but then it doesn't update? The hamburger menu is red so shows live data sources.
Red only means you have defined datasource not that they are set to autoupdate (play/pause indicator next to time interval) Quote: Also JOSN call don't seem to be working? Work fine in a browser.
What does not working mean ? from the helpfiles" "This supports JSON data that is stored as an object array. Each element in the array will be treated as a row."
