Cursor Size - How do I get cursor to show larger?
Joined: 4/6/2022(UTC) Posts: 31  Location: Los Angeles Thanks: 3 times
How do I get cursor to show larger? Seems like the display capture is only showing default size of cursor, even though I have increased the size on the windows 11, and it shows very large as I move the mouse around, however, when I look at the FULL SCREEN monitor, it shows as tiny, and not green colored, as it should be showing?
