curiousgeorge
#1 Posted : Friday, August 11, 2023 4:03:04 PM(UTC)
curiousgeorge
How do I get cursor to show larger?
Seems like the display capture is only showing default size of cursor, even though I have increased the size on the windows 11, and it shows very large as I move the mouse around, however, when I look at the FULL SCREEN monitor, it shows as tiny, and not green colored, as it should be showing?
