Systems
Opinions about Alienware Aurora R16 for small scale streaming?
The work load is audio and video streaming using 3 networked PTZOptics NDI cameras to Zoom, a local large screen TV, and local recording, for worship services. I am running the cameras at 720p and is currently sufficient. I expect it to eventually increase to 1080p. There will be some text overlays and output compositing multiple camera sources. It will be a mix of speech and music. No SDI sources. I am looking for a system that could eventually handle simultaneous streaming to multiple output targets (local large monitor, Zoom, YouTube, maybe others) and be future proof for the next 4 years or so. Any thoughts on a system consisting of: * 13th Gen Intel Core i7-13700F (16-Core, 54MB Cache, up to 5.2 GHz with Turbo Max 3.0) * NVIDIA GeForce RTX 4070 Ti, 12GB GDDR6X * 16 GB DDR5 RAM @ 5600 MT/s, https://www.dell.com/en-...desktop/useahbtsr16iglnzThanks for your opinions!
Joined: 2/8/2023(UTC) Posts: 23  Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
If "Streaming settings" uses the option "Use Stream 1 quality" for all streams, then additional streams do not create additional load on cpu/gpu.
Systems
