MikeStr
#1 Posted : Friday, August 4, 2023 2:55:33 AM(UTC)
MikeStr
The work load is audio and video streaming using 3 networked PTZOptics NDI cameras to Zoom, a local large screen TV, and local recording, for worship services.
I am running the cameras at 720p and is currently sufficient. I expect it to eventually increase to 1080p.
There will be some text overlays and output compositing multiple camera sources.
It will be a mix of speech and music.
No SDI sources.
I am looking for a system that could eventually handle simultaneous streaming to multiple output targets (local large monitor, Zoom, YouTube, maybe others) and be future proof for the next 4 years or so.
Any thoughts on a system consisting of:
* 13th Gen Intel Core i7-13700F (16-Core, 54MB Cache, up to 5.2 GHz with Turbo Max 3.0)
* NVIDIA GeForce RTX 4070 Ti, 12GB GDDR6X
* 16 GB DDR5 RAM @ 5600 MT/s,
https://www.dell.com/en-...desktop/useahbtsr16iglnz
Thanks for your opinions!
kuuminsh
#2 Posted : Tuesday, August 8, 2023 9:56:19 PM(UTC)
kuuminsh
Latvia
If "Streaming settings" uses the option "Use Stream 1 quality" for all streams, then additional streams do not create additional load on cpu/gpu.
