Akis1982
#1 Posted : Tuesday, July 18, 2023 10:32:52 PM(UTC)
Akis1982
Greece
"How can I set up a timer that goes beyond 60 minutes, for example, 90 minutes, which I need for a soccer match?"
fenki86
#2 Posted : Tuesday, July 18, 2023 10:43:07 PM(UTC)
fenki86
You have been a member since:: 3/6/2013(UTC)
In the Title Designer click on Settings next to the Play/Pause/Stop-Buttons. Then set the duration on 1:30:00 and the display format to mm:ss - if you click reverse and start the clock it'll count upwards and continue after 59:59 with 60:00, 60:01 and so on.
thanks 1 user thanked fenki86 for this useful post.
Akis1982 on 7/18/2023(UTC)
DougieDK
#3 Posted : Tuesday, August 1, 2023 12:31:04 AM(UTC)
DougieDK
Denmark
You could also look at using vMic UTC. In there its a lot easier/advanced regarding timing option. Plenty of tutorials on Youtube as well.
-Gary
