Joined: 7/18/2023(UTC) Posts: 1  Location: Athens Thanks: 1 times
"How can I set up a timer that goes beyond 60 minutes, for example, 90 minutes, which I need for a soccer match?"
Thanks: 22 times Was thanked: 10 time(s) in 10 post(s)
In the Title Designer click on Settings next to the Play/Pause/Stop-Buttons. Then set the duration on 1:30:00 and the display format to mm:ss - if you click reverse and start the clock it'll count upwards and continue after 59:59 with 60:00, 60:01 and so on.
 1 user thanked fenki86 for this useful post.
You could also look at using vMic UTC. In there its a lot easier/advanced regarding timing option. Plenty of tutorials on Youtube as well.
-Gary
