Audio turns off when switching camera inputs
Joined: 9/16/2021(UTC) Posts: 2  Location: Brevard Thanks: 2 times
I added a PTZ Move Camera physically to a location that had a G2 PTZ camera. Where the Move now is has an audio input cable to the sound board at Mix 1. We moved the G2 camera to another location without an audio cable. So I added the new Move camera to a Stream input since it a IP camera. The issue is when I switch from the Move camera to the G2 I loose master audio so we loose audio to the stream feed. How can I get audio to work on the G2 input? I can turn the audio button back on and audio is ok when on the G2. Ideas?
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Originally Posted by: JayBird  I added a PTZ Move Camera physically to a location that had a G2 PTZ camera. Where the Move now is has an audio input cable to the sound board at Mix 1. We moved the G2 camera to another location without an audio cable. So I added the new Move camera to a Stream input since it a IP camera. The issue is when I switch from the Move camera to the G2 I loose master audio so we loose audio to the stream feed. How can I get audio to work on the G2 input? I can turn the audio button back on and audio is ok when on the G2. Ideas? Hello. If i understand well, you must in the move camera input to un-check the Automatically mix audio option. And then audio will not go off when you change camera
 1 user thanked nikosman88 for this useful post.
