JayBird
#1 Posted : Sunday, July 16, 2023 5:13:56 AM(UTC)
JayBird
I added a PTZ Move Camera physically to a location that had a G2 PTZ camera. Where the Move now is has an audio input cable to the sound board at Mix 1. We moved the G2 camera to another location without an audio cable. So I added the new Move camera to a Stream input since it a IP camera.
The issue is when I switch from the Move camera to the G2 I loose master audio so we loose audio to the stream feed. How can I get audio to work on the G2 input? I can turn the audio button back on and audio is ok when on the G2. Ideas?
nikosman88
#2 Posted : Sunday, July 16, 2023 5:22:52 AM(UTC)
nikosman88
Greece
Hello. If i understand well, you must in the move camera input to un-check the Automatically mix audio option. And then audio will not go off when you change camera
thanks 1 user thanked nikosman88 for this useful post.
JayBird on 7/16/2023(UTC)
