Joined: 7/14/2023(UTC) Posts: 2  Location: Texas Thanks: 1 times
Has anyone housed the Elgato Cam Link Pro x4 HDMI input PCIE card in an external thunderbolt enclosure to use with a vMix laptop?
Did it work for you or did you run into problems?
What model enclosure did you use?
Joined: 3/26/2022(UTC) Posts: 11  Location: Cumbria Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: ken03  Has anyone housed the Elgato Cam Link Pro x4 HDMI input PCIE card in an external thunderbolt enclosure to use with a vMix laptop?
Thanks I just tested a Cam Link Pro in a Startech enclosure - works perfectly. https://www.amazon.co.uk...2ov_dt_b_product_details
 1 user thanked g7pfv for this useful post.
Originally Posted by: g7pfv  Originally Posted by: ken03  Has anyone housed the Elgato Cam Link Pro x4 HDMI input PCIE card in an external thunderbolt enclosure to use with a vMix laptop?
Thanks I just tested a Cam Link Pro in a Startech enclosure - works perfectly. https://www.amazon.co.uk...2ov_dt_b_product_details That's great, how long have you used/tested it with that enclosure? Did you connect it to a thunderbolt laptop and tested with vMix and did you use more than one camera?
Joined: 8/29/2015(UTC) Posts: 136 Location: Seattle Wa
Thanks: 16 times Was thanked: 14 time(s) in 13 post(s)
ive had it in a enclosure, putting it back into a new one ill have this week, i have not had any problems, ill test with my laptop. i got 3 capture cards in 1 thunderbolt case, so i think you will be fine.
Originally Posted by: ken03  Originally Posted by: g7pfv  Originally Posted by: ken03  Has anyone housed the Elgato Cam Link Pro x4 HDMI input PCIE card in an external thunderbolt enclosure to use with a vMix laptop?
Thanks I just tested a Cam Link Pro in a Startech enclosure - works perfectly. https://www.amazon.co.uk...2ov_dt_b_product_details That's great, how long have you used/tested it with that enclosure? Did you connect it to a thunderbolt laptop and tested with vMix and did you use more than one camera? Now tested for around 40 hours - zero issues, 2 cameras @1080 to test
