ken03
#1 Posted : Friday, July 14, 2023 8:22:31 PM(UTC)
ken03
Has anyone housed the Elgato Cam Link Pro x4 HDMI input PCIE card in an external thunderbolt enclosure to use with a vMix laptop?
Did it work for you or did you run into problems?
What model enclosure did you use?
g7pfv
#2 Posted : Friday, July 28, 2023 6:16:01 AM(UTC)
g7pfv
I just tested a Cam Link Pro in a Startech enclosure - works perfectly.
https://www.amazon.co.uk...2ov_dt_b_product_details
thanks 1 user thanked g7pfv for this useful post.
ken03 on 7/29/2023(UTC)
ken03
#3 Posted: : Saturday, July 29, 2023 12:17:41 AM(UTC)
ken03
That's great, how long have you used/tested it with that enclosure? Did you connect it to a thunderbolt laptop and tested with vMix and did you use more than one camera?
hellokitty
#4 Posted : Monday, August 7, 2023 2:53:23 PM(UTC)
hellokitty
ive had it in a enclosure, putting it back into a new one ill have this week, i have not had any problems, ill test with my laptop. i got 3 capture cards in 1 thunderbolt case, so i think you will be fine.
g7pfv
#5 Posted : Saturday, August 26, 2023 10:06:39 PM(UTC)
g7pfv
Now tested for around 40 hours - zero issues, 2 cameras @1080 to test
Similar Topics
Sonnet Echo Express and Elgato Cam Link Pro (Hardware Compatibility)
by g7pfv 1/12/2023 9:49:53 PM(UTC)
Two Elgato Cam Link Pro (Hardware Compatibility)
by elfabe028 9/1/2022 3:13:05 AM(UTC)
