SuperBill
#1 Posted : Tuesday, May 30, 2023 1:47:49 PM(UTC)
SuperBill
Canada
  • Theres the web-controller built in
  • There is also streamdeck with the vmix plugin (has portablity issues)
  • There is also streamdeck with Bitfocus's Companion (has other issues)
What else have you all used.
Does any one use UTC - universal title controller (https://elgarf.github.io/)
I currently use StreamDeck with Companion - but trying to move away from Streamdeck/Companion
Salvatore
#2 Posted : Tuesday, May 30, 2023 3:35:48 PM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
Here is a sample List of controllers you could use with vMix
https://www.vmix.com/sof...ardware.aspx#controllers
Dist
#3 Posted : Tuesday, May 30, 2023 8:32:57 PM(UTC)
Dist
Was thanked: 27 time(s) in 19 post(s)
What are your current issues with Companion and the reason to move away from it?
mavik
#4 Posted : Tuesday, May 30, 2023 9:26:09 PM(UTC)
mavik
Was thanked: 196 time(s) in 176 post(s)
Skaarhoj or MakePro X.
SuperBill
#5 Posted : Wednesday, May 31, 2023 12:50:22 AM(UTC)
SuperBill
Canada
Thanks Guys
I should have been clearer.
I'm trying to get more labeled buttons on one panel and trying to find a software only solution where I don't have to dig down into folders.
I need 64 from the mappings I've done, that leaves some buffer and allows for static buttons like bus kills and chanel mutes visible all the time.
Dist
#6 Posted : Wednesday, May 31, 2023 1:47:14 AM(UTC)
Dist
If your goal is to get away from folders, have you tried the web buttons interface for companion? You can have as many rows/columns on screen as you like, effectively allowing you to use a monitor/mobile device with hundreds of buttons visible at all times.
Or rather than folders you can make use of variables, or the shift feature so for example you could have 8 preview buttons, 8 program buttons, then hold shift and those same buttons are 8 different inptus, effectively doubling your buttons on a single Companion page.
thanks 1 user thanked Dist for this useful post.
SuperBill on 5/31/2023(UTC)
mavik
#7 Posted : Wednesday, May 31, 2023 7:51:55 PM(UTC)
mavik
You can also take a look into touchOSC and design your own surface to your liking.
