WatsonPrunier
#1 Posted : Sunday, May 7, 2023 5:21:25 AM(UTC)
WatsonPrunier
Groups: Guests
We already have the option that animates the layer in. How about the option to dissolve out or even wipe it out.
Currently, I have an animated title on layer 4 that I would like to disappear after certain time. It can be dissolved, wiped or even particle dissolved like a Thanos snap.
#2 Posted : Sunday, May 7, 2023 8:03:21 PM(UTC)
Layers or Overlays?
"like a Thanos snap" A what ?
WatsonPrunier
#3 Posted : Sunday, May 7, 2023 9:09:51 PM(UTC)
WatsonPrunier
Groups: Guests
Layers
#4 Posted : Sunday, May 7, 2023 9:38:58 PM(UTC)
add a trigger in the main input that has the GT title layer do the animationOut after a certain time when transitioning in the main input , if needed add an out animation to the title with the title designer to your liking
let a script do the wipe ( gradual pan ) on the layered input for example. a trigger or shortcut can call that script
WatsonPrunier
#5 Posted : Monday, May 8, 2023 8:14:58 AM(UTC)
WatsonPrunier
Groups: Guests
Thank you!
I will try the first, but I believe my need will be to upgrade to 4k or Pro so that I can use the Scripting. It appears the only way. I am assuming that I could probably created the dissolving in via the Advanced GT Title Designer???
