Groups: Guests
We already have the option that animates the layer in. How about the option to dissolve out or even wipe it out. Currently, I have an animated title on layer 4 that I would like to disappear after certain time. It can be dissolved, wiped or even particle dissolved like a Thanos snap.
Originally Posted by: social_wp@outlook.com  We already have the option that animates the layer in. How about the option to dissolve out or even wipe it out. Currently, I have an animated title on layer 4 that I would like to disappear after certain time. It can be dissolved, wiped or even particle dissolved like a Thanos snap. Layers or Overlays? "like a Thanos snap" A what ?
Groups: Guests
Quote:Currently, I have an animated title on layer 4 that I would like to disappear after certain time. add a trigger in the main input that has the GT title layer do the animationOut after a certain time when transitioning in the main input , if needed add an out animation to the title with the title designer to your liking Quote:How about the option to dissolve out or even wipe it out. let a script do the wipe ( gradual pan ) on the layered input for example. a trigger or shortcut can call that script
Groups: Guests
Thank you!
I will try the first, but I believe my need will be to upgrade to 4k or Pro so that I can use the Scripting. It appears the only way. I am assuming that I could probably created the dissolving in via the Advanced GT Title Designer???
