[vMix 2012] Decklink Studio Issue (2 Cards in 1 PC)
Hi, I've installed correctly 2 Decklink Studio v2 in my Workstation (core i5, 8Gb Ram), but I can't add the second capture device to vMix. I did this job with previous releases of vMix (finding "Decklink Video Capture (2)"), but the newest one seems not to display this second capture device. Any solution?
Thank you
Ok I managed to get it to work (Windows 7). Here's the solution that worked for me.
I installed both cards in the PC. Removed both Audio and Video Drivers Reinstalled the Audio and Video Drivers Deactivated the first card from windows devices Deactivated the second card from windows devices Reactivated the first card from windows devices Reactivated the second card from windows devices Windows prompted me to install some Decklink software, selected Yes Found the two capture devices in capture menu
Hope that someone with the same problem can find this solution useful.
Bye!
