Steve_T
#1 Posted : Tuesday, April 4, 2023 7:52:33 PM(UTC)
Steve_T
South Africa
Hi
I want to pull in a scoring feed to populate a Stats Graphic (goals scored, saves, etc.) for a Live Stream of a Water Polo Tournament. I have set up a Json feed out of the scoring software and tested that it is working. When I added that URL to the Data Sources Manager, nothing pulls through and I can't assign to the various stats sections in the Title Editor.
I seem to be missing a step?
#2 Posted : Tuesday, April 4, 2023 8:07:34 PM(UTC)
Originally Posted by: Steve_T Go to Quoted Post
Hi
Is the JSON data stored as an object array.? (see helpfiles)
Steve_T
#3 Posted : Tuesday, April 4, 2023 8:46:48 PM(UTC)
Steve_T
South Africa
No, they are stored as a string.
#4 Posted : Tuesday, April 4, 2023 9:20:29 PM(UTC)
https://forums.vmix.com/...g-JSON-Example#post63574
markleman
#5 Posted : Wednesday, April 5, 2023 8:02:40 AM(UTC)
markleman
Hi
I'm currently working on pulling in swimming data in JSON over a network using Python and updating vmix with it in real time using the vmix http API.
If you can't get the original JSON in a suitable form to act as a data source for vmix you could consider using python to reformat it.
Mark Leman
