Joined: 4/4/2023(UTC) Posts: 2  Location: Johannesburg
Hi
I want to pull in a scoring feed to populate a Stats Graphic (goals scored, saves, etc.) for a Live Stream of a Water Polo Tournament. I have set up a Json feed out of the scoring software and tested that it is working. When I added that URL to the Data Sources Manager, nothing pulls through and I can't assign to the various stats sections in the Title Editor.
I seem to be missing a step?
Joined: 12/27/2012(UTC) Posts: 5,513  Location: Belgium Thanks: 317 times Was thanked: 1021 time(s) in 838 post(s)
I seem to be missing a step? Is the JSON data stored as an object array.? (see helpfiles)
No, they are stored as a string.
Thanks: 12 times Was thanked: 3 time(s) in 3 post(s)
I seem to be missing a step? I'm currently working on pulling in swimming data in JSON over a network using Python and updating vmix with it in real time using the vmix http API. If you can't get the original JSON in a suitable form to act as a data source for vmix you could consider using python to reformat it. Regards, Mark Leman
