Josemite
#1 Posted : Wednesday, March 22, 2023 10:57:42 AM(UTC)
Josemite
I have several layouts for different "shows" (presets) and my shortcut list is huge and finding something to make a change is cumbersome. One show might have only 10 shortcuts and another has 50.
Also, I share the Web Controller with few people, so each show change I have to uncheck what shortcuts show up in the web controller. It's kind of a process to go in an uncheck and check the right ones. If the Shortcut list could be tied to the preset, it would be amazing for me. Or I could totally make it work if the shortcut list had their own profiles to switch between.
If none of that is remotely in the cards, a way to expand the shortcut window could be helpful.
scrollbar on shortcuts
dmwkr
#2 Posted : Wednesday, March 22, 2023 9:12:48 PM(UTC)
dmwkr
Right above the checkbox where you uncheck "Show in web controller", there is a checkbox "Local Shortcut (This preset only)".
https://www.vmix.com/hel...ocalGlobalShortcuts.html
