Joined: 6/4/2020(UTC) Posts: 40  Location: California Thanks: 14 times Was thanked: 4 time(s) in 4 post(s)
I have several layouts for different "shows" (presets) and my shortcut list is huge and finding something to make a change is cumbersome. One show might have only 10 shortcuts and another has 50. Also, I share the Web Controller with few people, so each show change I have to uncheck what shortcuts show up in the web controller. It's kind of a process to go in an uncheck and check the right ones. If the Shortcut list could be tied to the preset, it would be amazing for me. Or I could totally make it work if the shortcut list had their own profiles to switch between. If none of that is remotely in the cards, a way to expand the shortcut window could be helpful.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
