blackburst
#1 Posted : Friday, March 17, 2023 10:45:31 AM(UTC)
blackburst
Because mix inputs aren't accessible in the floating "add input" dialogue we can't change an input to a mix input. This would allow us to replace a single input with an upstream mix and have it carry through to all inputs and triggers that use it. I need to do it when one camera turns into a mix of two for example.
thanks 1 user thanked blackburst for this useful post.
vvcvvc on 3/25/2023(UTC)
fwieland
#2 Posted : Monday, March 20, 2023 11:27:14 PM(UTC)
fwieland
Switzerland
+1 from me
It would also be a huge time saver, if mix inputs could be used in other mix input in descending order, not ascending order. According to the manual, for example Mix 5 can not be fed into Mix 1 through 4, but can be fed into Mix 6 and the following. When I program a show, I normaly use Mix 1 through 4 as phisical outputs to comfidence monitors, Teams video return or local screen outputs. I prefer to set these up in the begining and is also part of my standard setup. If I now want to create a mix with all the cameras precut or all PC inputs, the I cannot use these in Mix 1 through 4.
This could be solved by reversing the order to allow Mixes with higher numbers to feed into mixes with lower numbers.
vvcvvc
#3 Posted : Saturday, March 25, 2023 6:48:14 AM(UTC)
vvcvvc
Estonia
+1
