Feature Requests
Change input to mix input
Joined: 1/25/2021(UTC) Posts: 13  Was thanked: 2 time(s) in 2 post(s)
Because mix inputs aren't accessible in the floating "add input" dialogue we can't change an input to a mix input. This would allow us to replace a single input with an upstream mix and have it carry through to all inputs and triggers that use it. I need to do it when one camera turns into a mix of two for example.
 1 user thanked blackburst for this useful post.
Joined: 11/21/2020(UTC) Posts: 36  Location: Zuerich Thanks: 7 times Was thanked: 1 time(s) in 1 post(s)
+1 from me It would also be a huge time saver, if mix inputs could be used in other mix input in descending order, not ascending order. According to the manual, for example Mix 5 can not be fed into Mix 1 through 4, but can be fed into Mix 6 and the following. When I program a show, I normaly use Mix 1 through 4 as phisical outputs to comfidence monitors, Teams video return or local screen outputs. I prefer to set these up in the begining and is also part of my standard setup. If I now want to create a mix with all the cameras precut or all PC inputs, the I cannot use these in Mix 1 through 4. This could be solved by reversing the order to allow Mixes with higher numbers to feed into mixes with lower numbers.
Joined: 3/28/2017(UTC) Posts: 70   Location: Haapsalu, Estonia Thanks: 75 times Was thanked: 3 time(s) in 3 post(s)
Feature Requests
