kon310
#1 Posted : Saturday, March 11, 2023 5:47:32 AM(UTC)
kon310
I am running a show whereby the "host" is remote. The issue I'm running into is when i want to switch to his OBS, which i bring in via Vmix call (Virtual Webcam), or SRT, for gameplay or anything that is running on his PC i can hear myself coming over his vmix call. that is because OBS is picking up the entirety of his desktop audio.
Is there a fast and easy way to solve this? I'm open to all suggestions (for my own knowledge) but in reality I can't make a lot of changes if any at all on his computer such as installing new software and things like that.
Thanks for any help anyone can give on this!
mavik
#2 Posted : Wednesday, March 22, 2023 5:06:54 AM(UTC)
mavik
I could see a way with vmix running on both sides. The basic HD 60$ would be sufficient. Then you have the call(up to 1080) within vMix, are able to add the screen capture as a source there directly and you can use the buses and different audio outputs so that no loop is happening.
Another way is to use a mobile phone with headset for the call.
a third option, if he sends via SRT and you use mobile phones for comms. There are intercom or pushToTalk apps available for free
nikosman88
#3 Posted : Friday, March 24, 2023 12:42:12 AM(UTC)
nikosman88
Greece
Try to use virtual cables app. See this video for reference on how to do it
