fluozh
#1 Posted : Monday, March 6, 2023 3:49:42 PM(UTC)
fluozh
Japan
Was thanked: 15 time(s) in 12 post(s)
hello, I was trying to understand how TCP API works.
So I made simple Library for Rust, it is now capable to receive/send commands.
however, it seems some events are missing from vMix side.(my code should be correct).
when I switch program by e.g. cut, sometimes TCP API does not send switched event.
log(correct behavior):
Code:
recv acts ActivatorsResponse { status: OK, body: InputPreview(57, false) }
recv acts ActivatorsResponse { status: OK, body: InputPreview(58, true) }
recv acts ActivatorsResponse { status: OK, body: Input(57, false) }
recv acts ActivatorsResponse { status: OK, body: Input(58, true) }
(input 57 deactivated, and 58 activated)
log(bug?)
Code:
recv acts ActivatorsResponse { status: OK, body: InputPreview(61, false) }
recv acts ActivatorsResponse { status: OK, body: InputPreview(57, true) }
recv acts ActivatorsResponse { status: OK, body: Input(60, false) }
(input 60 deactivated, vMix should send Input(57,true) event but it does not)
code: https://github.com/Flowi...lob/main/examples/cli.rs
