3rd Party Software and Development
TCP API SUBSCRIBE ACTS is missing some events
Joined: 3/18/2021(UTC) Posts: 46   Location: Tokyo Thanks: 19 times Was thanked: 15 time(s) in 12 post(s)
hello, I was trying to understand how TCP API works. So I made simple Library for Rust, it is now capable to receive/send commands. however, it seems some events are missing from vMix side.(my code should be correct). when I switch program by e.g. cut, sometimes TCP API does not send switched event. log(correct behavior): Code:recv acts ActivatorsResponse { status: OK, body: InputPreview(57, false) }
recv acts ActivatorsResponse { status: OK, body: InputPreview(58, true) }
recv acts ActivatorsResponse { status: OK, body: Input(57, false) }
recv acts ActivatorsResponse { status: OK, body: Input(58, true) }
(input 57 deactivated, and 58 activated) log(bug?) Code:recv acts ActivatorsResponse { status: OK, body: InputPreview(61, false) }
recv acts ActivatorsResponse { status: OK, body: InputPreview(57, true) }
recv acts ActivatorsResponse { status: OK, body: Input(60, false) }
(input 60 deactivated, vMix should send Input(57,true) event but it does not) code: https://github.com/Flowi...lob/main/examples/cli.rs
