susie lavender
#1 Posted : Saturday, February 25, 2023 8:24:26 AM(UTC)
susie lavender
FFMPEG1.Exited
ffmpeg started on 2023-02-24 at 16:07:03
Report written to "C:\ProgramData\vMix\streaming\streaming1 20230224-160703.log"
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
libavutil 55. 76.100 / 55. 76.100
libavcodec 57.106.101 / 57.106.101
libavformat 57. 82.101 / 57. 82.101
libavdevice 57. 8.101 / 57. 8.101
libavfilter 6.105.100 / 6.105.100
libswscale 4. 7.103 / 4. 7.103
libswresample 2. 8.100 / 2. 8.100
libpostproc 54. 6.100 / 54. 6.100
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 15509.784000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 04ccef20] TCP Buffer has been set to 6571008 bytes
rtmps://1373857056 :40a873dfac748aff @live-api-s.facebook.com:443/rtmp/647930603806122?s_asc=1&s_bl=1&s_oil=2&s_psm=1&s_sw=0&s_tids=1&s_vt=api-s&a=AbzTszmHp_dpm8LX: I/O error
sinc747
#2 Posted : Tuesday, February 28, 2023 6:11:23 AM(UTC)
sinc747
You've probably figured this out by now, but the easiest way to get a Definitive answer to this is by contacting vMix Tech Support directly (support@vmix.com). Also, in your vMix setup, in Settings --> About, send a Support Report. Be sure to include your vMix Registration number with your email.
Best of luck!
- Tom
Similar Topics
Error code: 0x80070057 (General Discussion)
by MikeAllenSports 4/2/2022 5:23:17 AM(UTC)
#200 error code on FB live login (General Discussion)
by Beauwulf 5/21/2017 1:53:07 PM(UTC)
