Joined: 1/8/2019(UTC) Posts: 15  Location: dallas tx Thanks: 1 times
FFMPEG1.Exited ffmpeg started on 2023-02-24 at 16:07:03 Report written to "C:\ProgramData\vMix\streaming\streaming1 20230224-160703.log" ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers built with gcc 4.8.1 (rev2, Built by MinGW-W64 project) configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686 libavutil 55. 76.100 / 55. 76.100 libavcodec 57.106.101 / 57.106.101 libavformat 57. 82.101 / 57. 82.101 libavdevice 57. 8.101 / 57. 8.101 libavfilter 6.105.100 / 6.105.100 libswscale 4. 7.103 / 4. 7.103 libswresample 2. 8.100 / 2. 8.100 libpostproc 54. 6.100 / 54. 6.100 Guessed Channel Layout for Input Stream #0.1 : stereo Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio': Duration: N/A, start: 15509.784000, bitrate: 1536 kb/s Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 29.97 fps, 29.97 tbr, 10000k tbn, 10000k tbc Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s [tcp @ 04ccef20] TCP Buffer has been set to 6571008 bytes rtmps://1373857056 :40a873dfac748aff @live-api-s.facebook.com:443/rtmp/647930603806122?s_asc=1&s_bl=1&s_oil=2&s_psm=1&s_sw=0&s_tids=1&s_vt=api-s&a=AbzTszmHp_dpm8LX: I/O error
Joined: 8/2/2013(UTC) Posts: 1,096   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
You've probably figured this out by now, but the easiest way to get a Definitive answer to this is by contacting vMix Tech Support directly (support@vmix.com). Also, in your vMix setup, in Settings --> About, send a Support Report. Be sure to include your vMix Registration number with your email.
Best of luck!
- Tom
