is there a way to get the Stream status (Disconnected, Successful, Starting, Intermittent) outside of vMix?
I tried it with Bitfocus Companion, but it only outputs true or false...
For example we want to trigger a external light to make it more visible if something is wrong with the Stream.
Is there a helpful documentation which i haven´t found?
Thanks in advance!
Joined: 11/15/2021(UTC) Posts: 87  Thanks: 8 times Was thanked: 12 time(s) in 10 post(s)
 1 user thanked Salvatore for this useful post.
Joined: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: Salvatore  which does as OP stated: only true or false (streaming activator) but not the other options ( Starting, Intermittent etc) the activator can easily be used to indicate in colors on a streamdeck if streaming is active or not ( no need for companion or script) BTW code in link is "borrowed" from : https://forums.vmix.com/posts/m71124-Scripting-for-Dummies#post71124
Thanks: 21 times Was thanked: 11 time(s) in 9 post(s)
Thanks in advance! I have found that this is a feature we are lacking. I know just what you mean, when the internet throughput slows down, vMix simply drops frames and carries on for ever. The result is a poor show for viewers and on contacting vMix, they confirmed there is no way, other than watching the streaming logs. Out of frustration, I started modifications to our routing management software so that each streaming log is monitored for real-time buffering. From that, when detected, the options for each stream are to stop and start it, stop and do nothing, stop and start a different stream ( eg a lower speed that you have set up in advance ). Still testing, but we are getting close to a working solution. Following is a screenshot. It would have been good if vMix could work on this area of resilience and stability.  Screenshot CtasRoute.jpg (213kb) downloaded 6 time(s).
 2 users thanked grantcoll for this useful post.
