t.sto
#1 Posted : Wednesday, February 22, 2023 10:58:48 PM(UTC)
t.sto
Germany
is there a way to get the Stream status (Disconnected, Successful, Starting, Intermittent) outside of vMix?
I tried it with Bitfocus Companion, but it only outputs true or false...
For example we want to trigger a external light to make it more visible if something is wrong with the Stream.
Is there a helpful documentation which i haven´t found?
Thanks in advance!
Salvatore
#2 Posted : Monday, February 27, 2023 6:27:27 AM(UTC)
Salvatore
Italy
Was thanked: 12 time(s) in 10 post(s)
You can display the Status on a external Monitor
Check this:
https://tvcrew.ch/vmix/d...ft_das_streaming_stream1
Scroll to
„läuft das streaming (stream1)?“
thanks 1 user thanked Salvatore for this useful post.
t.sto on 2/27/2023(UTC)
#3 Posted : Monday, February 27, 2023 6:52:53 AM(UTC)
Check this:
Scroll to
which does as OP stated: only true or false (streaming activator) but not the other options ( Starting, Intermittent etc)
the activator can easily be used to indicate in colors on a streamdeck if streaming is active or not ( no need for companion or script)
BTW code in link is "borrowed" from : https://forums.vmix.com/posts/m71124-Scripting-for-Dummies#post71124
grantcoll
#4 Posted : Friday, April 14, 2023 6:23:55 PM(UTC)
grantcoll
Originally Posted by: t.sto Go to Quoted Post
Thanks in advance!
I have found that this is a feature we are lacking. I know just what you mean, when the internet throughput slows down, vMix simply drops frames and carries on for ever. The result is a poor show for viewers and on contacting vMix, they confirmed there is no way, other than watching the streaming logs. Out of frustration, I started modifications to our routing management software so that each streaming log is monitored for real-time buffering. From that, when detected, the options for each stream are to stop and start it, stop and do nothing, stop and start a different stream ( eg a lower speed that you have set up in advance ).
Still testing, but we are getting close to a working solution. Following is a screenshot. It would have been good if vMix could work on this area of resilience and stability.
Screenshot CtasRoute.jpg (213kb) downloaded 6 time(s).
thanks 2 users thanked grantcoll for this useful post.
t.sto on 4/14/2023(UTC), nikosman88 on 5/26/2023(UTC)
