Receiving Multitrack Audio via RTMP
Joined: 9/24/2021(UTC) Posts: 8  Location: Düsseldorf Was thanked: 1 time(s) in 1 post(s)
Hi!
We use the audio multi channel system from vMix to send different audio channels with the stream. From our restream server I can tell, that it seems to work so far - it says it receives 6 Channels instead of the usual 2 channels. But when I pull that stream back to vMix via the VLC/RTMP plugin, I can only choose between the 2 usual audio channels in the audio settings for that input. Is there a way to get it working? Does the "options" field (next to the stream URL while setting up the input) help in any way?
Thank you & best regards, Daniel // SPONTENT GmbH
