SPONTENT
#1 Posted : Friday, February 10, 2023 3:23:55 AM(UTC)
SPONTENT
Germany
Hi!
We use the audio multi channel system from vMix to send different audio channels with the stream. From our restream server I can tell, that it seems to work so far - it says it receives 6 Channels instead of the usual 2 channels. But when I pull that stream back to vMix via the VLC/RTMP plugin, I can only choose between the 2 usual audio channels in the audio settings for that input. Is there a way to get it working? Does the "options" field (next to the stream URL while setting up the input) help in any way?
Thank you & best regards,
Daniel // SPONTENT GmbH
