Instant Replay
-3 Replay with custom Outpoint?
I am trying to set up shortcuts for a -3 in point but a custom outpoint. For exapmle i want one key to capture the replay but -3 seconds and the other to mark the outpoint.
Here's the closest I could come up with, but it is a two-button workflow. Essentially a MarkIn -3 button and then a MarkOut button.
Write a script: First function to ReplayMarkInOutLive for 3 seconds (this will mark to the -3 seconds from when you press the button). For the second function ReplaySelectLastEvent. Assign this script to your MarkIn -3 shortcut button.
On the second shortcut button assign ReplayUpdateSelectedOutPoint. That will update the outpoint of the selected event when you press the shortcut.
There may be a way to put this in one script that will wait for a second button press to run the ReplayUpdateSelectedOutPoint function. However, my scripting skill level is not that high yet.
Best of luck, C
Instant Replay
