DanDaMan
#1 Posted : Thursday, February 2, 2023 1:25:27 PM(UTC)
DanDaMan
I am trying to set up shortcuts for a -3 in point but a custom outpoint.
For exapmle i want one key to capture the replay but -3 seconds and the other to mark the outpoint.
cjzphotovideo
#2 Posted : Friday, February 17, 2023 9:12:49 AM(UTC)
cjzphotovideo
Here's the closest I could come up with, but it is a two-button workflow. Essentially a MarkIn -3 button and then a MarkOut button.
Write a script: First function to ReplayMarkInOutLive for 3 seconds (this will mark to the -3 seconds from when you press the button). For the second function ReplaySelectLastEvent. Assign this script to your MarkIn -3 shortcut button.
On the second shortcut button assign ReplayUpdateSelectedOutPoint. That will update the outpoint of the selected event when you press the shortcut.
There may be a way to put this in one script that will wait for a second button press to run the ReplayUpdateSelectedOutPoint function. However, my scripting skill level is not that high yet.
Best of luck,
C
Guest (4)
