#1 Posted : Monday, January 23, 2023 3:14:53 PM(UTC)
26.0.0.30
Initial release
thanks 9 users thanked admin for this useful post.
dunk on 1/23/2023(UTC), eduardocfs on 1/23/2023(UTC), IsaieS on 1/23/2023(UTC), xun on 1/24/2023(UTC), avsoundguy on 1/24/2023(UTC), RingsideReport on 1/24/2023(UTC), jet on 1/24/2023(UTC), Soundfloss on 2/3/2023(UTC), sinc747 on 2/4/2023(UTC)
#2 Posted : Friday, January 27, 2023 3:03:01 PM(UTC)
26.0.0.32
* Improved SRT CBR PCR handling
* Various bug fixes for effects including when used with Mirror, GT inputs, Photos/PowerPoint inputs and Virtual inputs when opened from a Preset
* Performance improvement for effects, by only rendering once when used with a static Image input
thanks 10 users thanked admin for this useful post.
gpdipalmerahtimur on 1/27/2023(UTC), jet on 1/27/2023(UTC), Peter Berglund on 1/27/2023(UTC), eduardocfs on 1/27/2023(UTC), raugert on 1/28/2023(UTC), Gunnar on 1/29/2023(UTC), nicademus on 1/29/2023(UTC), QuiapoChurch on 1/31/2023(UTC), Teye on 2/1/2023(UTC), sinc747 on 2/4/2023(UTC)
#3 Posted : Thursday, February 2, 2023 4:31:04 PM(UTC)
26.0.0.35
* Fixes and improvements to Effects handling in Virtual and PTZ inputs
Effects will now refer to original inputs effects by default with a checkbox similar to Colour Correction tab
* Audio selection hidden for Insta360 Link to prevent confusion, as Insta360 Link Microphone needs to be added as its own input
thanks 6 users thanked admin for this useful post.
eduardocfs on 2/2/2023(UTC), raugert on 2/2/2023(UTC), Peter Berglund on 2/3/2023(UTC), QuiapoChurch on 2/3/2023(UTC), sinc747 on 2/4/2023(UTC), jet on 3/6/2023(UTC)
#4 Posted : Friday, February 3, 2023 4:35:02 PM(UTC)
26.0.0.36
* Added Alpha Mask Effect, use PNG files to quickly add masks to inputs!
* Fixed Use Source Settings checkbox for Effects not being saved in preset
jet on 2/3/2023(UTC), Peter Berglund on 2/3/2023(UTC), Soundfloss on 2/3/2023(UTC), DetoxX on 2/3/2023(UTC), sinc747 on 2/4/2023(UTC), eduardocfs on 2/4/2023(UTC), NiBTour on 2/10/2023(UTC), AngusFindlay on 2/14/2023(UTC), doa on 2/18/2023(UTC)
#5 Posted : Monday, February 6, 2023 12:28:05 PM(UTC)
26.0.0.37
* Fixed line spacing from GT titles imported from PSD not displaying correctly
* Fixed List input not displaying rotated/vertical videos correctly.
QuiapoChurch on 2/6/2023(UTC), monamiga on 2/6/2023(UTC), eduardocfs on 2/6/2023(UTC), raugert on 2/7/2023(UTC), tridenator on 2/7/2023(UTC), Peter Berglund on 2/8/2023(UTC), ask on 2/8/2023(UTC), jet on 3/6/2023(UTC), sinc747 on 3/8/2023(UTC)
#6 Posted : Monday, February 13, 2023 12:05:45 PM(UTC)
26.0.0.38
* Fix aspect ratio issue with 4:3 sources in List input
* Fix SRT outputs not turning off correctly when also changing other SRT settings at the same time
eduardocfs on 2/13/2023(UTC), Chircanu on 2/13/2023(UTC), Peter Berglund on 2/13/2023(UTC), ask on 2/14/2023(UTC), QuiapoChurch on 2/14/2023(UTC), liangbo on 2/14/2023(UTC), raugert on 2/18/2023(UTC), jet on 3/6/2023(UTC), sinc747 on 3/8/2023(UTC)
#7 Posted : Monday, March 6, 2023 3:49:03 PM(UTC)
26.0.0.40
* Added support for multiple audio tracks in SRT streams from OBS
* Fixed memory leak in SRT inputs when the source is constantly reconnecting
* Fixed Stream Delay not working with LiveLAN
* Stream settings in Stream Quality that are shared across al streams (such as stream delay) now appear on all streams in the interface but are greyed out.
These settings can still only be edited from Stream 1.
thanks 7 users thanked admin for this useful post.
jet on 3/6/2023(UTC), eduardocfs on 3/6/2023(UTC), QuiapoChurch on 3/7/2023(UTC), stigaard on 3/7/2023(UTC), raugert on 3/8/2023(UTC), sinc747 on 3/8/2023(UTC), ask on 3/21/2023(UTC)
#8 Posted : Wednesday, April 12, 2023 2:39:47 PM(UTC)
26.0.0.42
* NEW Audio Track selection option for SRT input, to select only a single audio track from the source instead of all at once.
* NEW audio support when using SRT inputs with Replay
* Fix for Title Preset CSV exports when using " quotes
eduardocfs on 4/12/2023(UTC), sinc747 on 4/13/2023(UTC), Gunnar on 4/14/2023(UTC), mgrayeb on 4/14/2023(UTC), jet on 4/20/2023(UTC), QuiapoChurch on 4/20/2023(UTC)
#9 Posted : Tuesday, May 2, 2023 2:39:24 PM(UTC)
26.0.0.44
* NEW NAL CBR option in Streaming Quality settings. See help for more information.
https://www.vmix.com/help26/StreamingQuality.html
* Removed discontinued streaming destinations
* Old FFmpeg removed due to licensing issue.
eduardocfs on 5/3/2023(UTC), Simsyuk on 5/3/2023(UTC), sinc747 on 5/4/2023(UTC), Chircanu on 5/4/2023(UTC), nikosman88 on 5/10/2023(UTC), jet on 7/1/2023(UTC)
#10 Posted : Friday, July 21, 2023 12:20:14 PM(UTC)
26.0.0.45
* vMix Social: Added workaround for bug in Facebook's live comments API.
* vMix Social: Removed Twitter support.
* Fix for activators not working correctly on some Mix numbers.
* Fix for dragging the T-Bar sometimes causing Virtual Set layers to move.
* Fix for GT titles in layers getting stuck when the main input is not set to autoplay.
Simsyuk on 7/21/2023(UTC), cparrap on 7/22/2023(UTC), RingsideReport on 7/22/2023(UTC), QuiapoChurch on 7/23/2023(UTC), sinc747 on 7/23/2023(UTC), Bonbondotkom on 9/2/2023(UTC), madness on 10/10/2023(UTC)
Guest (11)
