Joined: 1/13/2010(UTC) Posts: 5,366  Location: Gold Coast, Australia Was thanked: 4786 time(s) in 1643 post(s)
 9 users thanked admin for this useful post.
26.0.0.32
* Improved SRT CBR PCR handling * Various bug fixes for effects including when used with Mirror, GT inputs, Photos/PowerPoint inputs and Virtual inputs when opened from a Preset * Performance improvement for effects, by only rendering once when used with a static Image input
 10 users thanked admin for this useful post.
26.0.0.35
* Fixes and improvements to Effects handling in Virtual and PTZ inputs Effects will now refer to original inputs effects by default with a checkbox similar to Colour Correction tab * Audio selection hidden for Insta360 Link to prevent confusion, as Insta360 Link Microphone needs to be added as its own input
 6 users thanked admin for this useful post.
26.0.0.36
* Added Alpha Mask Effect, use PNG files to quickly add masks to inputs! * Fixed Use Source Settings checkbox for Effects not being saved in preset
26.0.0.37
* Fixed line spacing from GT titles imported from PSD not displaying correctly * Fixed List input not displaying rotated/vertical videos correctly.
26.0.0.38
* Fix aspect ratio issue with 4:3 sources in List input * Fix SRT outputs not turning off correctly when also changing other SRT settings at the same time
26.0.0.40
* Added support for multiple audio tracks in SRT streams from OBS * Fixed memory leak in SRT inputs when the source is constantly reconnecting * Fixed Stream Delay not working with LiveLAN * Stream settings in Stream Quality that are shared across al streams (such as stream delay) now appear on all streams in the interface but are greyed out. These settings can still only be edited from Stream 1.
 7 users thanked admin for this useful post.
26.0.0.42
* NEW Audio Track selection option for SRT input, to select only a single audio track from the source instead of all at once. * NEW audio support when using SRT inputs with Replay * Fix for Title Preset CSV exports when using " quotes
26.0.0.45
* vMix Social: Added workaround for bug in Facebook's live comments API. * vMix Social: Removed Twitter support. * Fix for activators not working correctly on some Mix numbers. * Fix for dragging the T-Bar sometimes causing Virtual Set layers to move. * Fix for GT titles in layers getting stuck when the main input is not set to autoplay.
