sunkast
#1 Posted : Wednesday, January 18, 2023 10:17:35 AM(UTC)
sunkast
Tonight I was rewriting a script I use for a program to change the output of Output 2 using the SetOutput2 parameter to a specific input. After adding my new script I hit the start button to execute the script to test it. It worked as I had expected. That is until I clicked the OK button to close the settings dialog. As soon as I clicked the OK button, Output 2 changed back to Output, away from the input the script set Output 2 to. This does not occur if I trigger the script using a different method. I am able to reproduce this one 2 different PCs. Is this the intended behavior? Using vMix v25.0.0.34 on Windows 10.
#2 Posted : Wednesday, January 18, 2023 12:25:49 PM(UTC)
Was thanked: 4735 time(s) in 1624 post(s)
Yes, this is intended behaviour.
Clicking OK in settings will save and apply all settings to vMix. This includes what you have set in Settings -> Outputs.
The Scripting tab is for testing only, if you want to actually start/stop the scripts there during a production you will need to create some shortcuts.
sunkast on 1/18/2023(UTC)
