Possible bug executing scripts from settings dialog
Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Tonight I was rewriting a script I use for a program to change the output of Output 2 using the SetOutput2 parameter to a specific input. After adding my new script I hit the start button to execute the script to test it. It worked as I had expected. That is until I clicked the OK button to close the settings dialog. As soon as I clicked the OK button, Output 2 changed back to Output, away from the input the script set Output 2 to. This does not occur if I trigger the script using a different method. I am able to reproduce this one 2 different PCs. Is this the intended behavior? Using vMix v25.0.0.34 on Windows 10.
Joined: 1/13/2010(UTC) Posts: 5,370  Location: Gold Coast, Australia Was thanked: 4794 time(s) in 1646 post(s)
Yes, this is intended behaviour. Clicking OK in settings will save and apply all settings to vMix. This includes what you have set in Settings -> Outputs.
The Scripting tab is for testing only, if you want to actually start/stop the scripts there during a production you will need to create some shortcuts.
Martin vMix
