Thanks: 16 times Was thanked: 11 time(s) in 9 post(s)
Akai have just released their APCMini MKII which features RGB pads, would be great to update VMIX to add support for that, would make the display way better. Its a great controller for VMIX, we use the MKI with a Cloud instance and VirtualUSBHere BTW, found some decent stickers for the button tops: https://www.flexilabels....&printColors=priceNPJust need to cut 2mm off the bottom of the label and your golden Thanks
You have been a member since:: 3/12/2019(UTC) Posts: 22  Location: Hamburg Was thanked: 3 time(s) in 3 post(s)
I found a solution: Just choose the Akai APC 40 MKII LED colours and you can use all RGB colours. An other solution ist to edit the activator colour in the preset file by a text editor (was my first solution).
So no update needed!
 1 user thanked Henrik for this useful post.
Joined: 7/27/2022(UTC) Posts: 31  Thanks: 11 times Was thanked: 2 time(s) in 2 post(s)
Here's how to Change the Brightness, make it Blink or Pulse:
change the channel of the Note , see this table from the manual:
MIDI Channel | Function 1 | On 10% brightness 2 | On 25% brightness 3 | On 50% brightness 4 | On 65% brightness 5 | On 75% brightness 6 | On 90% brightness 7 | On 100% brightness 8 | Pulsing 1/16 9 | Pulsing 1/8 10 | Pulsing 1/4 11 | Pulsing 1/2 12 | Blinking 1/24 13 | Blinking 1/16 14 | Blinking 1/8 15 | Blinking 1/4 16 | Blinking 1/2
