nowski
#1 Posted : Thursday, December 22, 2022 1:21:55 AM(UTC)
nowski
Akai have just released their APCMini MKII which features RGB pads, would be great to update VMIX to add support for that, would make the display way better.
Its a great controller for VMIX, we use the MKI with a Cloud instance and VirtualUSBHere
BTW, found some decent stickers for the button tops:
https://www.flexilabels.co.uk/product/270-rectangle-labels-per-a4-sheet-178-mm-x-10-mm?quantity=5&material=30&printColors=priceNP
Just need to cut 2mm off the bottom of the label and your golden
Henrik
#2 Posted : Friday, February 10, 2023 7:31:59 AM(UTC)
Henrik
Germany
I made a post in "Feature Requests":
https://forums.vmix.com/posts/t30001-Activators-for-the-new-APC-mini-MKII--2023
I use 9mm Dymo Label priter tape and benzoe as additional glue.
Henrik
#3 Posted : Sunday, February 12, 2023 4:52:17 AM(UTC)
Henrik
Germany
I found a solution: Just choose the Akai APC 40 MKII LED colours and you can use all RGB colours. An other solution ist to edit the activator colour in the preset file by a text editor (was my first solution).
So no update needed!
thanks 1 user thanked Henrik for this useful post.
Bonbondotkom on 9/30/2023(UTC)
Bonbondotkom
#4 Posted : Monday, September 18, 2023 12:19:14 AM(UTC)
Bonbondotkom
Philippines
Here's how to Change the Brightness, make it Blink or Pulse:
change the channel of the Note , see this table from the manual:
MIDI Channel | Function
1 | On 10% brightness
2 | On 25% brightness
3 | On 50% brightness
4 | On 65% brightness
5 | On 75% brightness
6 | On 90% brightness
7 | On 100% brightness
8 | Pulsing 1/16
9 | Pulsing 1/8
10 | Pulsing 1/4
11 | Pulsing 1/2
12 | Blinking 1/24
13 | Blinking 1/16
14 | Blinking 1/8
15 | Blinking 1/4
16 | Blinking 1/2
