Sebastien
#1 Posted : Sunday, November 13, 2022 10:34:17 AM(UTC)
Sebastien
Canada
Hello there,
I'm trying to bring the main output without the overlays back into Vmix. Using NDI does add latency which doesn't work for what I want to do. I was trying to create a input with the "output" option, which bring the output back fine into Vmix, but even if I disable overlays on Output #1, they always show up on this input. Is there a way to disable which overlays show up on the "output" input in Vmix ?
RichDanby
#2 Posted : Sunday, November 13, 2022 10:47:42 PM(UTC)
RichDanby
Was thanked: 29 time(s) in 26 post(s)
Interesting - I assumed you had got something wrong but I'm getting the same.
You can get slightly less latency (& load) than NDI by adding a camera input, selecting Show Legacy devices at the bottom of the Camera drop down and then picking vMix Video, and turning on external output. It does still have a bit more latency than the output input but it does show what overlays are on Output 1 (use vMix Video 2 for Output 2)
Guest (4)
