"Output" input always bring all the overlays
Hello there,
I'm trying to bring the main output without the overlays back into Vmix. Using NDI does add latency which doesn't work for what I want to do. I was trying to create a input with the "output" option, which bring the output back fine into Vmix, but even if I disable overlays on Output #1, they always show up on this input. Is there a way to disable which overlays show up on the "output" input in Vmix ?
Joined: 2/23/2019(UTC) Posts: 139  Thanks: 20 times Was thanked: 29 time(s) in 26 post(s)
Interesting - I assumed you had got something wrong but I'm getting the same.
You can get slightly less latency (& load) than NDI by adding a camera input, selecting Show Legacy devices at the bottom of the Camera drop down and then picking vMix Video, and turning on external output. It does still have a bit more latency than the output input but it does show what overlays are on Output 1 (use vMix Video 2 for Output 2)
