Thanks: 3 times Was thanked: 6 time(s) in 6 post(s)
Is there a way to use Multicorder to record each selected input to audio only? I know it's possible to record an input with both audio and video, or to use WAV File Record for a separate wav file. But I only want to record the audio, not the video, to save on space and resources.
I found this old post. I have the same question. (How) is this possible?
@ JoostH
Audio only recording is not possible with vMix, the best you can do is record a WAV file in conjunction with the video recording, and then delete the video recording if it is not needed or wanted.
