gre2gor
#1 Posted : Monday, November 7, 2022 8:05:02 PM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
Hey,
How can I transition or even set sources in Mix2, Mix3 via web scripting? I would like to transition via some script or similar every 15-20 seconds. Possible?
Grega
nikosman88
#2 Posted : Monday, November 7, 2022 8:11:06 PM(UTC)
nikosman88
Greece
Yes you have to specify mix input number in the command. for example Function=CrossZoom&Input=My input&Duration=500&Mix=0 this is a simple crosszoom command for main mix. For mix1 you will give Mix=1
