Mix2, Mix3 switching with web scripting
Joined: 12/14/2018(UTC) Posts: 87  Was thanked: 18 time(s) in 7 post(s)
Hey, How can I transition or even set sources in Mix2, Mix3 via web scripting? I would like to transition via some script or similar every 15-20 seconds. Possible? Grega
Joined: 12/24/2021(UTC) Posts: 733  Location: athens Thanks: 166 times Was thanked: 99 time(s) in 95 post(s)
Yes you have to specify mix input number in the command. for example Function=CrossZoom&Input=My input&Duration=500&Mix=0 this is a simple crosszoom command for main mix. For mix1 you will give Mix=1
