Continuous rotation of a image
I need a Continuous rotation of a image, I put it in a "CD" player, the image update when my radio automation change the current song. How do I do it?
Joined:: 12/27/2012(UTC) Posts: 5,534  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: itarsc3  I need a Continuous rotation of a image, GT Title designer: add image , select animation tab - continuous in storyboard - rotateContinuous option Or check one of the multiple vMix tutorial videos ;-) https://youtu.be/-2JfCd4Ss6w
The animation is as a CD Player, not in this way. And in GT I can't update it every 5 seconds
Originally Posted by: itarsc3  The animation is as a CD Player, not in this way. And in GT I can't update it every 5 seconds You will need ot explain much better what your intention is
Originally Posted by: itarsc3  https://codepen.io/StrengthandFreedom/pen/BaaQYqw an animation similar to this. My radio playout gets "OnAir.png" image when the song change. This image will rotate under an alpha mov That is exactly how i explained it before !! One can rotate in different directions and it can be a flat image instead of on a cube shape . is it is in a GT title one can change the image on the fly withotu chamging the animation behavior. Open your GT title desinger and add an image and set the animation !
The image with GT does it automatically update when changed?
Originally Posted by: itarsc3  The image with GT does it automatically update when changed? It doesn't working, when the image changes it remains the same
Originally Posted by: itarsc3  Originally Posted by: itarsc3  The image with GT does it automatically update when changed? Not working, when the image changes it remains the same WHere are the images stored? How are you changing the image reference? are you changing the image manually(as test) or through datasource within the title? Is the title either "playing" or in Overlay as else the animation will not be visible ? Pls in future elaborate on the problems you encounter , meaning "it doesn work" is not helping much in getting a good answer FYI changing an image in a GT Title does work and the animation remains as set
