itarsc3
#1 Posted : Monday, October 31, 2022 9:38:13 PM(UTC)
itarsc3
Italy
I need a Continuous rotation of a image, I put it in a "CD" player, the image update when my radio automation change the current song. How do I do it?
#2 Posted : Monday, October 31, 2022 10:45:24 PM(UTC)
GT Title designer: add image , select animation tab - continuous in storyboard - rotateContinuous option
Or check one of the multiple vMix tutorial videos ;-)
https://youtu.be/-2JfCd4Ss6w
itarsc3
#3 Posted : Monday, October 31, 2022 11:09:07 PM(UTC)
itarsc3
Italy
The animation is as a CD Player, not in this way. And in GT I can't update it every 5 seconds
#4 Posted : Monday, October 31, 2022 11:48:39 PM(UTC)
You will need ot explain much better what your intention is
itarsc3
#5 Posted : Tuesday, November 1, 2022 12:06:04 AM(UTC)
itarsc3
Italy
https://codepen.io/StrengthandFreedom/pen/BaaQYqw an animation similar to this. My radio playout gets "OnAir.png" image when the song change. This image will rotate under an alpha mov
#6 Posted : Tuesday, November 1, 2022 12:27:30 AM(UTC)
That is exactly how i explained it before !! One can rotate in different directions and it can be a flat image instead of on a cube shape . is it is in a GT title one can change the image on the fly withotu chamging the animation behavior.
Open your GT title desinger and add an image and set the animation !
itarsc3
#7 Posted : Tuesday, November 1, 2022 1:17:30 AM(UTC)
itarsc3
Italy
The image with GT does it automatically update when changed?
itarsc3
#8 Posted : Tuesday, November 1, 2022 1:50:09 AM(UTC)
itarsc3
Italy
It doesn't working, when the image changes it remains the same
#9 Posted : Tuesday, November 1, 2022 3:24:21 AM(UTC)
Not working, when the image changes it remains the same
WHere are the images stored?
How are you changing the image reference?
are you changing the image manually(as test) or through datasource within the title?
Is the title either "playing" or in Overlay as else the animation will not be visible ?
Pls in future elaborate on the problems you encounter , meaning "it doesn work" is not helping much in getting a good answer
FYI changing an image in a GT Title does work and the animation remains as set
