Henny
#1 Posted : Tuesday, October 18, 2022 4:39:46 AM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
check your value for Name, Table
see the attached screenshots, this works fine in 2.3.1 (2.3.1+4641-v2-3.1-dc01ac7c)
Screenshot 2022-10-17 192339.png (17kb) downloaded 26 time(s). Screenshot 2022-10-17 193514.png (14kb) downloaded 24 time(s).
geekazine
#2 Posted : Tuesday, October 18, 2022 5:08:26 AM(UTC)
geekazine
You are using Google Sheets. I am converting to Excel/CSV due to work flow.
Hypohamish
#3 Posted : Tuesday, October 18, 2022 9:43:39 AM(UTC)
Hypohamish
The type of data has nothing to do with it - once it's in vMix, the same cue will act the same way
I'd advise you to look at his screenshots carefully, because I can assure you that the command you're trying to use in companion works just fine, so there's a user error on your side.
dmwkr
#4 Posted : Wednesday, October 19, 2022 12:45:54 AM(UTC)
dmwkr
Most probably a small mistake in the naming. Maybe a space in the end of the name? Is your datasource really called "Excel/CSV" and the table "Sheet1"? Btw, it is good practice to give your datasource a real telling name, not the default name.
gre2gor
#5 Posted : Wednesday, October 19, 2022 9:41:11 AM(UTC)
gre2gor
Slovenia
Was thanked: 18 time(s) in 7 post(s)
YOu have to select Row one time at the start. Then it works. Once I have dynamic data captured and there are some rows I trigger this with extra button on Streamdeck. I have it labeled "Select 0" and is on it's own page, since I need it only one time starting the event.
Grega
wbenben
#6 Posted : Thursday, March 20, 2025 12:29:16 AM(UTC)
wbenben
I had the same problem and I entered everything with case sensitive and it works
