Data Source - Next Row on Companion Not Working?
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
check your value for Name, Table see the attached screenshots, this works fine in 2.3.1 (2.3.1+4641-v2-3.1-dc01ac7c)  Screenshot 2022-10-17 192339.png (17kb) downloaded 26 time(s). Screenshot 2022-10-17 193514.png (14kb) downloaded 24 time(s).
Joined: 12/30/2020(UTC) Posts: 7  Location: Madison, WI Thanks: 3 times
You are using Google Sheets. I am converting to Excel/CSV due to work flow.
Joined: 12/19/2020(UTC) Posts: 57  Location: London Thanks: 2 times Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: geekazine  You are using Google Sheets. I am converting to Excel/CSV due to work flow. The type of data has nothing to do with it - once it's in vMix, the same cue will act the same way I'd advise you to look at his screenshots carefully, because I can assure you that the command you're trying to use in companion works just fine, so there's a user error on your side.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Most probably a small mistake in the naming. Maybe a space in the end of the name? Is your datasource really called "Excel/CSV" and the table "Sheet1"? Btw, it is good practice to give your datasource a real telling name, not the default name.
Joined: 12/14/2018(UTC) Posts: 88  Was thanked: 18 time(s) in 7 post(s)
YOu have to select Row one time at the start. Then it works. Once I have dynamic data captured and there are some rows I trigger this with extra button on Streamdeck. I have it labeled "Select 0" and is on it's own page, since I need it only one time starting the event.  Elgato_SelectRow.jpg (39kb) downloaded 23 time(s).Grega
I had the same problem and I entered everything with case sensitive and it works
