Duff TV
#1 Posted : Friday, October 31, 2014 12:24:50 AM(UTC)
Duff TV
UPDATE: After doing some research it looks like the Beldon 1505 RG59 is the go but here is my post anyway.
Doing a live switch in 2 days so hoping for some feedback ASAP.
I plan on running SDI 1080 over Beldon RG6 QUAD coax.
Commonly my runs will be up to 30M but some will be maybe 60M.
I have about 300m of the RG6 left over from a job I did 10 years ago and its in 50 and 100m lengths at present. Its terribly bulky and hard to coil so the option is there to ditch it buy RG59. A tech friend tells me the "strandard Dual Shield" type is the go.
Here are my questions;
1. Is RG59 fine for smallers runs say up to 30m?
2. Would joining 2X RG59's meana a possible loss in quality?
3. Is joining a RG59 to a RG6 cable an issue?
Based on this video I should be bypassing the quad cable and going for a dedicated SDI cable that has 95% Tin Cooper braid.
Thanks in advance,
Regards
Martin Duffy
javascript:__doPostBack('forum$ctl01$PostReply','')
